hi, was able to test the QS last week, the setting are at default, just wanted to find out if I should increase or decrease the timing to get a smoother gear change, im changing anywhere between 7 and 11k, the lower end gives me a bit a hard shunt. am I right in saying that's cos of the timing setting or is it something else ?
If you get any miss shifts try reducing the sensitivity 5% at a time untill it all seems good if it stops shifting you have gone to far
I'm glad you mentioned that cos I had a couple of miss shifts from 1st to 2nd and thought it was me or the bike doing something wrong I'll try adjusting that too, thanks
1-2 is a little hit and miss on the plus to be fair but the less sensitive it is the cleaner it shifts
I didn't really play with it until the way home and I may stop smiling soon its fantastic mate! Do I need it.........NO Is it worth it.........YES!!! It's really weird to get used too but what a buzz
