HM quickshifter help plz
Discussion in 'HM Quickshifter' started by wedgiewolves#223, Jan 30, 2013.
  1. wedgiewolves#223
    wedgiewolves#223 God Like
    Hi there everyone got my quickshifter rod sent so I'm all ready to fit well I thought I was
    I know the sensor screws onto my original threaded bar that comes off the joint at top but then at the bottom it's a female end and my rod has 2 female ends am I missing a bit of threaded bar to join the 2 ?????
    Hope this makes any sense
  2. Repsol Rob
    Repsol Rob Elite Member
  3. wedgiewolves#223
    Thanks bud I think I'm missing a piece of threaded bar where the sensor meets the shift bar as you have 2 lock nuts there grrrrrrrrrr !
  4. Repsol Rob
    yup.....6mm i think ?
  5. wedgiewolves#223
    I have old bar left over from my translogic ill chop that off the bar and put inbetween should be ok thanks Repsol
  6. wedgiewolves#223
    Sorted cut a bit of bar off thanks ImageUploadedByTapatalk1359577591.945020.jpg
  7. wedgiewolves#223
    Run into another snag he original top mount on gearbox with the rose joint is a left handed thread the sensor has 2 right sided threads the only way I could jolt it up is this way . I purchased this second hand but new been on show bike does the kit from HM come with bracket that fits on gearbox shaft ? I don't know whether to run it like this as quite close to frame this is my only other little snag ha ha ImageUploadedByTapatalk1359592744.837991.jpg
  8. bladerunner2010
    bladerunner2010 Active Member
    I would say your load cell is on the wrong end of the connecting rod??
  9. wedgiewolves#223
    Yeah I know this but the load cell has normal thread where as my joint it has to screw on in the top is left hand thread so im stuck
  10. wedgiewolves#223
    Just spoke to Ben at HM quickshifter they are so helpful the load cell accepts left hand and right hand threads . I just didn't want to force it but it will be the right way up tonight ha ha thanks guys
    #10 wedgiewolves#223, Jan 31, 2013
