hm quickshifter setting help????
Discussion in 'Maintenance' started by coley65, Jun 5, 2013.
  1. coley65
    coley65 New Member
    hows things lads i have a quck question for some one that might know a bit about these quick shifters i just want to know what sensetivity and kill time setting would be the best and does any one have one and what are your settings if your happy with the gear change mine is a small bit jumpy when going up through the gears just want to get it as smooth as possible??
  2. fez.57
    fez.57 Well-Known Member
    What rear sets are you using as this can make a differance. if its lurching when shifting then your kill time is too long. 65 kill time is good for midrange shifting and 62 for redline area.
    You need to set your sensetivity so your lcd screen flashes shift just before it changes gear
