Hm super lite issues
Discussion in 'Maintenance' started by rosier1uk, May 26, 2015.
  1. rosier1uk
    rosier1uk Active Member
    Hi guys
    Ok having a few issues with the hm superlight
    Ok it's intermittent sometimes when I turn the ignition on the qs just flashes fast instead of the the 3 flashes I usually get to let me no sensitivity and no response on shifter when I put pressure on gear leaver. If I turn bike on and off few times it seems to reset itself I am very cautious about using the quick shifter when riding in case it's failing intermittently whilst riding in case I wreck the gearbox there's plenty play on the rose joints and gear shift is solid
    Hopefully someone can point me in the right direction ( hoping Arthur bike mad might jump in on this post)
    Many thanks in advance
    Brian
  2. mattnz
    mattnz New Member
    Hi
    did you ever sort this out? I'm having the exact same problem with my hm superlite on a gsx s1000.
  3. rosier1uk
    Yes mattnz
    I rang Hm they said it was just the quick shifter self calibrating itself nothing to worry about
    Regards
    Brian
  4. mattnz
    mattnz New Member
    Thanks for the quick reply.
    Ok, was yours working when it was behaving like this?.Mine started doing it today, the reason I noticed was because it wouldn't work.
    I ended up riding about 250 kms with it like this and stopped several times and turned the ignition on and off, it never started to work.
  5. rosier1uk
    Yes was working mate give Hm a ring there a great bunch and will be happy to help
    Cheers
