Hole position for R&G frame sliders - 2007
Discussion in 'Mods, Upgrades, Accessories and Products' started by B626, Mar 23, 2023.
  1. B626
    B626 New Member
    Hi all,
    When I bought the bike I also bought a set of R&G cut frame sliders for my 07 blade. Never got round to installing them until now.
    Have marked out the centrepoint for drilling the hole but noticed that the 28mm diameter bore specified in the instructions would mean the hole 'overhangs' the edge of the fairing...
    Does anyone also have an 06/07 blade with these sliders installed and if so can you confirm if the hole for them is meant to be fully contained within the fairing or whether it overhangs like it seems to on mine.
    My fairings are custom made ones so potentially measurements are off...
    Cheers
  2. dern
    dern Well-Known Member
    These are pictures of mine installed but the bodywork is chinese replica stuff I use for track days...
  3. dern
    Here's a couple more...
  4. Selmer50mark
    Selmer50mark God Like
    07 blade , yes the holes on mine overhang
  5. dern
    I think I only cut a hole for the spacer and not the actual slider.
  6. B626
    B626 New Member
    Thanks for the input chaps, still on the fence about whether I really want to cut through the edge of the fairing rather than just a hole...
    Have either of you had the pleasure of actually using them in anger, did they fair well?
  7. Selmer50mark
    :eek: Not intending to use mine o_O:D
    • Funny Funny x 2
  8. Lock
    Lock Active Member
    Hole is a half circle shape on mid fairing - were installed on bike when I got it. Don't like bungs so removed, now left with silly cutouts! My advice don't drill out fairings - either get no drill bungs or leave off. Shame you hadn't got a HRC, would have swapped my fairings with you and save you the hassle :)
  9. B626
    B626 New Member
    Any particular reason you don't like bungs?
    Heard very bad things about the no drill bungs for 07. Along the lines of it needing the engine dropped to replace secondary damage to the water pump outlet caused by them collapsing...
  10. dern
    Not yet
  11. Lock
    Lock Active Member
    Just look to be honest, doesn't do it for me.
