I need to get bits, rubbers, bolts etc, some of the items I need I cannot find in the relevant section. for example on the headlight, I need the rubber grommits. but they are not listed and it references "F34", what is this, how do I order this part? https://www.bike-parts-honda.com/pi...00RRA-2010-F__0100-CBR+1000+RR+FIREBLADE.html ive put a screenshot. thanks in advance
Jim, it's something a dealer will have to resolve. The situation is that when a part is surrounded with a box and an 'F' or 'E' reference (for instance) it generally means that the part comes with another assembly or mating component. This is best illustrated (for your understanding) by looking at 'Air Intake Duct' where you will see 'E19'. That 'E19' is a component of 'Injector' (or vice versa). It might well be that you cannot order the particular grommet on its own because it comes as part of an assembly. If it's any further help, there are a range of grommet suppliers on eBay (who won't have an idea of the size you require). I use this company https://www.thegrommetcompany.com/open-grommets which, once again, is only useful if you know the size of the grommet you need. Perhaps you have an old headlight unit you can get the size from. Cheers!
Hi Mate Have a look at Fowlers parts for your bike under ‘upper cowl’ if the grommets you need are the ones on the clock bracket that the pegs on the headlight slide on to you should find them there. You can get the part number for them if you want to get them elsewhere.
I was just about to post the same thing. The grommets are listed under No. 17 in the Upper Cowl section.
