Honda CBR1000RR 2004 2007 Engine Frame Loads of spares
Discussion in 'Parts, Accessories & Clothing' started by SBK, Mar 2, 2015.
  1. SBK
    SBK New Member
    Job Lot of Honda Fireblade spares.
    Engine is 2006/7 Numbers are present and correct,engine is a full runner with no faults and has had
    very little use.
    Frame is a replacement but i have the Vin tag so possibly could be registered,as you can see it has been partially blasted.
    Included in the sale are swingarm,Yokes,Fuel tank (Dented but usable)complete with pump,
    Box of brand new gearbox parts several Gearboxes! (unsure if complete) engine casings,pistons and rings,several sets of inlet and exhaust valves,clutch friction plates and pressure plates some new some good.
    Engine mounting bolts,swingarm,airbox,throttle bodies,standard and race spec bellmouths,assorted cam chain tensioners some HRC also.Engine casings some good some not so.
    also pair of bmc filters,downpipes and link pipe.
    Needs coming to see as there is stuff i have probably forgot.
    £500
  2. Blackness
    Blackness Active Member
    Where do you live dude ? Seriously interested !!!!
  3. Blackness
  4. SBK
    SBK New Member
    Still here,bargain of the year.
  5. SBK
    SBK New Member
  6. SBK
    SBK New Member
    No longer available.
