Honda CBR1000RRR SP 2016 abs front module bleeding help?
Discussion in 'General 1000RR Discussion' started by MichaelV, Apr 2, 2023.
  1. MichaelV
    MichaelV New Member
    Hello
    I change the line to the front abs module and now I don't have good front brake follow all instructions https://www.dropbox.com/s/3ytel9ml9dcp94p/C-ABS Bleed Notes V8.pdf?dl=0
    But can't bleed the front abs module can you help me?
    Thanks!!!
    The bike is on 4k miles
  2. Coda
    Coda Active Member
    Did you also read the service manual? It might some have extra info your missing.
    That said, I think you need to remove the radiator to get to the front module.
    To be honest, the first time I am faced with this, I’m probably just gonna remove the whole lot.
    Good luck.
  3. MichaelV
    MichaelV New Member
    Hello
    I found only this fail, no I haven't remove radiator I buy the long tools which I can bleed without remove any side plastic or radiator,thank you but really abs module give me a headache..
