Honda Fireblade CBR1000rr 17-19 Dynojet Power Commander V For Sale
Discussion in 'Parts, Accessories & Clothing' started by vic_ster51, Jul 26, 2023.
  1. vic_ster51
    vic_ster51 Active Member
    part number - 16-068
    £165
    The Power Commander gives you the freedom to adjust the fuel map to guarantee a perfect setting. You don't have to be a mechanic to know which map you should choose, as Dynojet offers a large database of maps (free to download), which include many combinations of motorcycles and aftermarket parts that go along with a specific map. If that map doesn't meet your needs as you would like, a custom map can be created as well. The custom map gets created from the ground up and needs to be setup using a dyno.
    Some benefits:
    - Fuel maps can be setup to meet your wishes
    - Allows up to 24 different fuel tables for 6-speed four cylinder bikes.
    - Switch between 2 different maps while you ride, by using the map switch (not included)
    - OEM style connectors
    - Adjustbale fuel map to RPM, throttle position and per gear.
    - Free Dynojet C3 mobile app available on Google Play to communicate and adjust your installed Power Commander V, to calibrate throttle position, configure quick shifter options and enable REV X-tend. (requires a cable that's available separately)
  2. vic_ster51
