Honda tank badge removal
Discussion in 'Maintenance' started by lexathon, Dec 5, 2016.
  1. lexathon
    lexathon Active Member
    Anyone had any success removing the tank badges in such a way that they can be re-used after a respray?
    I was thinking sticky stuff remover and a bit of heat. Don't want to risk breaking them though.
  2. Womblewizard
    Womblewizard Active Member
    I got some dental floss behind them and applied heat! With a little work came off with no problems!
  3. sps170373
    Warm up first with hairdryer and as Womble said use fishing line! If you can get someone to keep heat on while doing it all the better
  4. lexathon
    Thanks!! Much better idea than sticking a screwdriver underneath them!!
  5. sps170373
    Oh if you haven't got fishing line, dental floss works too
