Horn
Discussion in 'Maintenance' started by Boo634, Jul 2, 2014.
  1. Boo634
    Boo634 New Member
    Hi everyone just failed my MOT on the horn not working well its making a strange noise now had a quick look without taking the nose cone off and there seems to be a plastic piece pressing against the front of the horn can't really see what it is but its stopping the horn sounding anybody got any ideas,and is taking the nose cone of as complicated as it looks in the manual cheers Boo
  2. marco s
    marco s Active Member
    My horn doesn't work after a few beers :D
  3. flurbs
    flurbs Active Member
    Not sure about the horn on the 'blade but could it be just a corroded connection terminal(s)? If you can get to the terminals try disconnecting them, clean/WD40 and pushing back?
  4. RRoss
    RRoss Active Member
    The horn could have moved,should be easy enough to twist it so nothing touches the front of it. Also,as said above,check the connections,clean and wd40,they easily get corroded by road dirt.
  5. Boo634
    Boo634 New Member
    Thanks will try your suggestions tomorrow many thanks Boo
