How do you remove pillion pegs?
Discussion in 'General 1000RR Discussion' started by andybow, Apr 29, 2011.
  1. andybow
    andybow Active Member
    Have just picked up my blade. Wow what a great bike have got some toys coming soon.ie new exhaust levers etc etc.........Does anyone here Know how to remoe the pillion pegs, I've just taken off the seat and can't seem to see how?
    Cheers Andy
  2. dan.1moore1
  3. garyauk
    garyauk Active Member
    Hi Andy,
    remove passenger and front seats, remove rear seat unit, undo top bracket that holds the seat catch, lift out fuse box to gain access to screw under it. there is another bracket underneath(just like the seat catch bracket) that needs to be removed. you have to remove the screws that hold the under tray/cowl...these are a bit of a pain. Now you are left with just the subframe that can be seperated into two parts. undo the mounting bolts for the subframe on 1 side only, and remove that side of the subframe, remove pegs and refit that side of the subframe. Now do the same for the other side of the subframe. I have heard of people bending up the plastic carrier that holds the battery etc but I found that this wasn't easy and it felt like things were going to break.
    This does sound a bit daunting but when you get stuck in , it is quite easy :)
    Have fun with it and take your time
  4. Brym
    Brym Active Member
    I am going to make up some plates out of Aluminium for mine so that I can easily put them back on whenever needed easily without removing half the bodywork etc
    Bit like these from Sato SATO RACING | CBR1000RR ('08- ) Racing Hooks
  5. dan.1moore1
    Yeah i saw those on 1000rr.net , Dont think i can face stripping the back down again. I already had my tank off to install an 02 sensor eliminator so i carried on and got the pegs off
  6. andybow
    Many thanks Gary, Will do it tomorrow morning! will let you know how I get on!
  7. andybow
  8. dan.1moore1
    Ha ha .. Its not that bad actually mate. No need to take the tank of, i only have it off in the pic as i done the 02 sensor eliminater at the same time.
    Just strip the back down slowly as described by garyauk and it should ony take an hour
  9. JM1
    JM1 Active Member
    You don't need to move the tank to fit the O2 sensor eliminator?
    (But you would have for the PC of course).
    andybow - now would be a good time to fit a tail tidy too btw.
  10. dan.1moore1
    For the dynojet eliminator no you don't , just reach up the side of the frame .
    However they would not sell me 1 with out PC-V
    I had to buy an eliminator from eBay that envolved disconnecting the oem connector, blanking of 2 wires then attaching the kit connector 2 the remaining wires and plugging in a resistor .
    It was alot Easyer with the tank off .
  11. JM1
    JM1 Active Member
    Sounds like a pain in the neck!
    You can get a DynoJet eliminator by quoting the serial number of a power commander, maybe someone else's pc ;)
  12. dan.1moore1
    Yeah it was a pain.
    All done now now thou.
    Good info for any one looking to get an eliminator thou.
    I spotted a dynojet eliminator on M&P's website for 20 bucks. They are a dynojet dealer so could be genuine
  13. blade1980
    blade1980 Active Member
    Rear pillion pegs - finally removed
    AT LAST!! Big thanks to gary. After reading many forums i decided to go for it, taking my time and working through carefully i have finally got my rear pillion pegs off, wasn't too bad a job, took about an hour and well pleased, bike looks so much better, just the yoshi to fit now to finish it off!:tongue:
  14. dan.1moore1
    Get some pics up mate
  15. matt
    matt Active Member
    picssssssssss
  16. andybow
    Thanks Gary, As above spent last night taking the pegs off so easy, with your help and a little time! will post some pics next week when I get some goodies put on!
    Cheers Andy
  17. matt
    matt Active Member
    hmmmm shall i pull mine off.......
  18. megawatt
    megawatt Well-Known Member
    Nice one, knew you could do it!!!
  19. garyauk
    Glad to be of assistance................Go on Matt, you know it makes sense :)
  20. megawatt
    PIX, PIX, PIX pleeeeeeeese????
