How many amps does the stock Stator generate?
Discussion in 'General 1000RR Discussion' started by si1000repsol, Oct 21, 2014.
  1. si1000repsol
    Hi,
    I am trying to work out how many amps the stock setup generates. I understand the HRC stator generates 15 amps so interested what is produced on a standard blade.
  2. arthurbikemad
    Afaik it's around 45amps. Also if I am right the HRC gen is only enough to run the ignition system and dash.
  3. si1000repsol
    So an electrex 25 amp setup should be better
  4. Kentblade
    Kentblade God Like
    Correct me if I am wrong but 15A at 15V is around 225watts. the output of a Blade varies between 372 & 417w depending on the year and model, so approx 24-28Amps, but then again it could all be bo**ocks
  5. arthurbikemad
    Better as in? power? weight?
    If they say 25 amps then I am confused, the older bike had a gen output of around 40-50 amps iirc so my guess is OEM 45amps..
  6. si1000repsol
    Yes electrex say their kit outputs 25 amps so looking for something lighter but being able to run the lights of a road bike.
  7. arthurbikemad
    Without doing the math V=IR your probberly right.
  8. arthurbikemad
    Thought so, tough call! I'd not change it tbh, but others may have a better idea, HRC gen switched lights, poss, last time I looked at HRC gen spec I was sure it said not for road use, as in, no lights..
  9. Kentblade
    Kentblade God Like
    Well I am working on the basis the the regulated voltage out of the alternator is 15V not 12V, so the maths is right for that case, all I know is that its enough to run the lights and keep all those ponies pumping out under electronic control
  10. arthurbikemad
    I'd say Kentblade is spot on!
  11. arthurbikemad
    Yep, I think your bang on mate.
  12. si1000repsol
    Glad I chose a HRC/Electrex setup in that case!
  13. Kentblade
    Kentblade God Like
    Holy crap. better add, I am not some kind of anal stats mupp, just happened to have me Haynes manual open when the thread popped up and it gives the alternator output in volts and watts.
    That's me story and I am sticking to it :rolleyes:
  14. arthurbikemad
    Ah ok ok, well your on the money haha, is this a case of Red Dwarf and Holly's encyclopaedia of space ;)
  15. si1000repsol
    Lol its much appreciated.
  16. gary.ritter2
    gary.ritter2 New Member
    Thanks for sharing Well I am working on.
  17. arthurbikemad
    So I have found 421w for an RR8, seems Mr Haynes is right...not that I doubted it lol
  18. si1000repsol
    Sounds like the setup will work a treat!
  19. Kentblade
    Kentblade God Like
    Not sure I like this Haynes bloke........freaking know it all, bet he spends most of his time on Wiki
  20. arthurbikemad
    Haha, yeah... mind you my facts have been wrong-isn twice today... lend us yer books pal... ;)
