how to check a part number
Discussion in 'Maintenance' started by raphael, Apr 28, 2016.
  1. raphael
    raphael Elite Member
    is there a anyway of checking a part i have recieved as it looks totally different to whats on the bike,are the front sprockets different on the abs/non abs
    cheers
  2. sps170373
    Where did you buy it from?
  3. sps170373
  4. raphael
    bought it from fowlers mate, it tells me its a front sprocket but it doesn't look like the one that's on my bike at the moment,and i can't see anywhere on there sight what bike it will fit
  5. sps170373
    Probably an aftermarket one they punt out
  6. sp1n99
    sp1n99 Active Member
    If it's an after market front sprocket it probably won't have the sound deadening rubber on it.
    If this is the only difference then it's fine. If you're going down a tooth then it will be after market.
