How to remove the tank
Discussion in 'Maintenance' started by samd1985, May 7, 2013.
  1. samd1985
    samd1985 Active Member
    Just after a bit of advice regarding fuel tank removal. I know it hinges up - I get that far, but I'm worried that by removing the fuel hose it'll spill petrol all over the place? I don't have a hose clamp but will buy one if I need to.
    It was never a problem on my previous bike as it had carbs and a fuel tap so could turn that off!
    Bike is a 2012 blade
    Thanks in advance
    Sam
  2. ColinBR
    No need for a hose clamp mate. They don't leak once disconnected.
  3. samd1985
    Thanks Colin. So I literally disconnect the hose at the tank connection and all should be ok?
  4. levin
    levin Active Member
    Yep had mine off 08 blade 2day, just push in the 2 little green locking tabs and it pulls straight off
  5. wedgiewolves#223
    wedgiewolves#223 God Like
    Had my tank off my 2012 couple of times there is a rubber grommet pull it from top to bottom then squeeze tabs . The rubber is just to stop the tabs being accidentally pushed in still a bit of a bugger to get off a screwdriver helps
  6. samd1985
    Thanks for the advice guys, much appreciated!
