How to remove Tilt Sensor CBR?
Discussion in 'General 1000RR Discussion' started by hump333, Jan 25, 2013.
  1. hump333
    hump333 Member
    Anyone got any info on removing the tilt sensor?
  2. lee711
    lee711 Active Member
    Quote taken from another site :-
    " Re: tilt sensor
    Originally Posted by holygrail720 View Post
    anyone removed their tilt/tip over sensor? how did you do it? thanks
    It can be done by simply removing it and splicing the wires together. However, I don't recommend it. If your bike falls over, the tilt sensor shuts off the fuel pump. If your bike is running, it'll stop. If it's on fire, fuel stops being fed. There are no inherant problems that I'm aware of, warranting it's removal. (IE: Suzuki's tend to stutter on hard cornering as there sensor is more sensitive)
    However...it's your bike. "
  3. hump333
    hump333 Member
    Thanks Lee, Thats what I'm worried about when I'm banking low so thinking get rid of it, cant splicing wires short out somewhere else?
  4. lee711
  5. hump333
    hump333 Member
  6. lee711
    lol. crazy cousins for ya.
  7. Jimbo Vills
    I've (and so have loads of people) scraped pegs on track and never been an issue mate - and not heard anyone having an issue - so I really wouldn't worry about it!?
    #7 Jimbo Vills, Jan 25, 2013
  8. phantom
    phantom Active Member
    +1 on what jimbo say's,
    I see some nutters scrapping pegs with elbow down
    and no issue's apart from scuffed leathers lol.
  9. lee711
    Have to agree with the guys here, i'm no pro but iv'e had the bike proper cranked over on the track with no issues, only when i came off on the road and the bike was lying on its side did the tilt sensor kick in and cut the engine out. needed when it was needed, not only to cut the fuel off but to prevent engine damage due to running without oil whilst lying in a slightly inverted position.
  10. Si.
    I wouldn't bugger about with what is essentially a safety aid dude. You may need it one day.
  11. Remal
    I have no issues when on track scratching the pegs and my knee on the floor
  12. Givover
    I only seem to get a small stall but this is only when I get the elbow and shoulder dug in deep to the Tarmac but when on the loose road clippings if I lift it an inch it seems fine .
  13. Remal
    I want to see the pic of you doing that?
  14. Kstead
    Kstead Active Member
    you dont get (big) side forcecs on a bike unless your stopped ie crashed or dropped, or you fit a side car so i wouldnt worry
