How would you mount a camera for a track day?
Discussion in 'Lounge' started by bluekontakt2004, Mar 18, 2012.
  1. bluekontakt2004
    bluekontakt2004 Active Member
    Got one of these
    Drift X170 Action Camera - Drift Innovation
    Just struggling with how i am going to mount it.
    Is tanktape strong enough to hold it to the side of the bike?
    Cant fit it to the top of the tank as I have a dark double bubble.
    I know i can remove the pillion seat and tape it to that with tape going all round it for rear view for a session or 2 but how about front view?
  2. r1monkey
    r1monkey Active Member
    just been in the garage looking at how i am going to mount mine.
    i have had it stuck on the side of my hemet at 150 mph ,with the sticky pad and clip that comes with the camera, but you cant have them stuck on your helmet or fuel tank on track days.
    if you are going to stick it on the fairing i would have a backup wire to fasten it to the bike just in case the tape fails.
    other than that i am looking at using the ram mount system from "adventure spec"
  3. Andrew
    Andrew Active Member
    How about attaching it to the fork leg or front mudguard
  4. BoroRich
    BoroRich Elite Member
    I heard of someone wrapping the heftiest jubilee clip they could find in black tape and putting it around their crash mushroom, using the bit of the clip that had gone through the ratchet to mount their camera too.
  5. bluekontakt2004
    you using the same cam? i was kind of thinking of using the remote strap on one of the other mounts around the indicator and lots of tanktape to keep it steady? what do you think?
  6. bluekontakt2004
    Dont have crash mushrooms.
  7. bluekontakt2004
    On my 05 blade their is no protuding fork leg to attatch it too and cant mnount it ontop of the mudgaurd as when i brake the top cowl will smash into it.
  8. bluekontakt2004
  9. megawatt
    megawatt Well-Known Member
    Suction mounts and sticky tape work, but the trackday marshals can ban them. Best bet is a mechanical / bolt on bracket that can't fall off. If anyone needs a bracket, I can make one for ya?
  10. bluekontakt2004
    Trouble is where can i mount it? everywhere is covered in plastic lol.
  11. bluekontakt2004
    see what i mean?
  12. megawatt
    I had a bracket to hold my Aldi camera pointing backwards, good when you pass people and when they pass you . Do you have any M8 or M6 bolts that you could bolt a bracket to, rearward or forward? I used an alternator M6 bolt once for a lowdown forward facing video?
    #12 megawatt, Mar 18, 2012
  13. Andrew
    What about lashing it to your mirror with plenty of tape?!
  14. bluekontakt2004
    I remove my mirrors on track days, stops me looking in them when I should be looking forwards.
  15. megawatt
    Can make ya a bracket to bolt to mirror mount if you remove mirror. Gotta be careful how you mount cameras to avoid shake and vibration. Solid mount, hold camera in a foam clamp and hopefully decent anti shake on camera !!!
  16. dan.1moore1
    Gaffa tape it to your helmet mate
  17. r1monkey
    i have a suction mount fot my sat nav. i tried it on top of the tank cover , but it wouldnt stick ,as the surface has to be perfectly flat ,and the top of the tank isnt.
  18. shanes
    shanes Active Member
  19. Jamiestrada
    Mmmmmm nice bike mister :) only 180 mph ????
  20. shanes
    they canceled the track at the last min that morning , so we had to ride on the public road
    here is a little clip
    TYGA Desmodici Thailand - YouTube
    here is one from to weeks ago on the RC8R at Sepang with some different angels you can try
    SBR Track Days - Feb 2012 - YouTube
