HRC Kit Discs 04-07 will fit 08>
Discussion in 'Parts, Accessories & Clothing' started by CastrolCraig, Jan 17, 2012.
  1. CastrolCraig
    CastrolCraig Active Member
    For sale I have a set of low mile (sub 500 mile) HRC Kit Catalouge discs, with a standard rear. These are removed from my 07 and are ready to go.
    Looking for 150 quid plus 15 posted.
    Cheers
  2. Nutty Tart
    Nutty Tart Well-Known Member
    Are you sure they will fit 08 ..... I do believe they would need a spacer ring to line up
  3. bluekontakt2004
    bluekontakt2004 Active Member
    are these the bigger 320mm discs or whatever they are? Do they require the 10mm calliper spacer?
  4. CastrolCraig
    I meant as in fitment, you are correct in saying they need 5mm spacers to use on the 08>
    Blukontakt they are the slightly lighter & considerably more abrasive 310mm discs, I'll try and get part number from HRC Catalouge for you.
