Apologies if this has been posted before but has anyone considered getting one of these HONDA CBR1000RR RACE ECU - UK ROAD AND RACE more info here ROGUE RACING HRC ECU CBR1000RR You seem to get a lot of toys at a 'reasonable' cost it's like a Power commander/bazza on steroids, just intrigued if anyone has one. Traction Control System(TCS): preventing rear wheel spinning by controlling the engine output with FI and IG, based on the rotation data of front and rear wheel detected by front wheel sensor and main shaft speed sensor. ● Anti Spinning Setting: preventing rear wheel spinning by retarding ignition timing, based on the abrupt engine rotation change. ● G/R Map IG Select: Ignition timing can be cusotmized differently for each gear ratio. ● Front Up Control Setting: preventing front wheel to come off the ground(wheelie) by controling engine power output with the reduction of fuel injection and the retard of ignition timing, based on the information from front wheel sensor and the main shaft speed sensor. (★) ● IACV(Idle Air Control Valve): this was realized by IACV setting(Ne and throttle valve opening). More optimized setting has become available for the character of the engine rotation with grip throttle completely closed. (★)
from research, it slots right into the standard harness but you need to make a jumper or two. I guess by the response it is not a popular mod either road or track, surprising though as it can provide quite a few tools.
I will be getting one of this... Not right away but in the foreseeable future. I'll let you know when it is time. But my tuner already said it is the best thing I can mount regrading ecu related mods.
