HRC Rear Brake Reservoir
Discussion in 'Mods, Upgrades, Accessories and Products' started by MrB, Nov 7, 2013.
  1. MrB
    MrB God Like
    Evening all,
    Anyone got the HRC tube fitted, wondering if anyone has a picture ?
    Had the kit a while but not sure whether to fit or not.
  2. Nutty Tart
    Nutty Tart Well-Known Member
  3. Nutty Tart
  4. MrB
    MrB God Like
    Ideal, thanks.
  5. MrB
    MrB God Like
    What have you used to attach to the sub frame ?
  6. Nutty Tart
    A plain ole cable tie ... weight saving ehh :D
  7. Skippy79
    Skippy79 Active Member
    the problem is with the HRC tubes, is that the brake fluid turns it creamy white after a while, and starts to look ugly..... otherwise, it saves a few gm :D
  8. Nutty Tart
    Maybe not as I use fully synthetic brake fluid ;)
  9. dr_tre100
    dr_tre100 New Member
    call me anal but I don't like the fact you have to bend the tube , on my gsxr the outlet is vertical so it sticks up and looks good , ive been debating about putting one on me blade but id prefere if I could get an elbow to make the outlet vertical rather than horizontal
  10. Garyb
    Garyb Moderator.
    Carbon or titanium? ;)
  11. ShinySideUp
    ShinySideUp Elite Member
    You could always fit a 90* pipe fitting like that of the link attached.
    90 Degree Hose Joiner Plastic Barbed Connector Pipe Fitting Air Fuel Water WHITE | eBay
  12. Skippy79
    Used dot 4 and dot 5 on my bikes before with this and within 6 months both looked crap, might still have one from the beginning of the year to post a pic
  13. Muffking
    I cut mine down thinking that I could fit the other half of the pipe when this one mists up, but that one's in a drawer in the garage and has gone and misted up now too. Must be the cold???
  14. Nutty Tart
    Not sure that its the cold as mine has been on the bike for over 2 years and as you can see in the pic it's still clear
  15. Skippy79
    could be a possible reaction to a type of fluid... not sure, but had them on 3 bikes, the first bike I sold after a month, so don't know what happened, but on my 08 blade it misted up and on my R6 it did as well, might also be because the brake was never used and the fluid just sat there without movement or anything... no idea
  16. Souleh
    Souleh Active Member
  17. Nutty Tart
    I would put my money on the type of fluid as I very rarely use the rear brake as well ;)
  18. Nutty Tart
    Don't take offence bud , not havin a dig ... but you mean hygroscopic . Hydroscopic is a device to view objects below the surface of water .
    That's one of those words often used incorrectly . I think the moisture you refer to is sweating of the fluid because the wrong type of plastic
    tube is used .
  19. Skippy79
    both of my tubes have been HRC tubes from honda, so not sure about that one, although I do know regular plastic clear tubes turn white and rock hard after a while as I do my bleeding with them and have to buy new ones every year
  20. Nutty Tart
    Ahhh you've got me there ... it's got to be the type of fluid then I suppose
