Hi All!! I was wondering if anyone here has any experience with the HrC traction control on a 08-14 Blade.. I've bought a race bike recently that has the HRC loom and ecu and was thinking of adding the traction control. From what I gather the HRC system only uses a front wheel speed sensor and no back wheel sensor. In my mind that would make it a lot less sophisticated than the stock zx10r or BMW systems but maybe I'm wrong. Anyone with any feedback please feel free to comment as I'd like to hear all pros and cons and whether it's a simple system to use it not!!
all after market TC are crap imo, I had a bazzaz one on my gsxr and it cut in way too early so I dialed it in lower and it still cut in too early, by the end of the day I had it turned off and was alot happier either one that's comes on a bike or nothing!
I had a Bazzaz system on my gsxr aswell!! Same as you I found it crap. Either kicks in too much or not at all. Didn't think the quickshifter was great either so pulled out the whole system again and put the bike back to standard!! I was hoping the HRC might be a better system with it being their own in house system.
Bazzaz Is Fine , but you have to customize the tc Map Hrc tc is using Speed Sensor as hr signal You have to Set gearing, M6 Pulse und tire sitze correct Then you have to enable tc sensity and how much tc Action you want based on fi and ign reduction Not Easy to Set up at all This Is for hrc 09 Version 08 Is Not Working well at all
I posted this a while back, might help.. might not.. http://1000rr.co.uk/mods-upgrades-accessories-products/8763.htm
