Well popped to see Tim blakemore Tim Blakemore Racing Motorcycle Dyno Tuning I told him I wanted to get a Bazzaz or similar fitted. he suggested the Bazzaz which I was glad. Need to save as I'm looking at in the future getting the system with the TC and Quick shifter fitted. Gear indicator, and K&N filter and Dyno time for a race and wet setting. Hoping it will make a big difference with the Yoshi R77 I have fitted. not looking for Huge BHP gains just a well sorted running blade. But would be nice to see what power the bikes kicking out after. Cost is not the issue at the moment. I could book it in for next week but due to the wife I will just book it in for it's service when due. and get this all done at the same time. :hail:
can't go wrong for that little cash. Looking like £690 for the bazzaz system. that's the all singing version Bazzaz.net - Z-Fi TC traction + quick shift + fuel thinking i'm not going to do this before I go to the US in march. £690 Vs $950. depending on the expanse rate I may see if I can get one from the us as that works out today at £605
Have you ever actually had an unintentional rear tyre slide (skids and wheelspins don't count) while cornerning on your Blade? I've seen the Bazzaz TC in action and it certainly functions as intended but if you want to see it work you'll need to be a fast rider! Also requires quite a lot of setup/fiddling. P.S. I'm not sure the Bazzaz TC has been tested in conjunction with nitrous injection
I've had the back end skidding on track. But thinking long term I would rather have a system in place to add these options then have to upgrade in the future
Remember you can always buy the Bazzaz as seperate units At the mo i am running the Bazzaz Fi with the Yoshi R77 and a pipercross air filter, even that little lot cost around £617 inc VAT to set up (Bazzaz, Filter, Dyno time/map)
Jus are also 5 mins away and did my first service and fitted my r77 can. I intend to see what prices they can both do for me before I hand over and money
