I won
Discussion in 'General 1000RR Discussion' started by viper_biker, Aug 11, 2012.
  1. viper_biker
    viper_biker Active Member
    Dickhead of the day. Went to fit a brand new genuine nose cone to the bike today only for it to crack and break into 3 pieces!!!
  2. honda.ima
    honda.ima Active Member
    Sorry
    Feel for you, will you try again?
  3. raphael
    raphael Elite Member
    gutted!! how did you manage that?
  4. Villan
    Villan Active Member
    Nightmare. Hamfisted?
  5. Andrew
    Andrew Active Member
    Major Oops!!!
  6. BLAGGERS
    BLAGGERS Well-Known Member
    What the fook was you fitting it with? A hammer? P.E to 'blow it' into place?
    Shit mate, thats an expensive balls up.
  7. Hudson
    Hudson Active Member
    Due to me knowing my limits and having the DIY capabilities of Mr Bean, it would have been in the dealer quick than you can say '' Don't tighten it that much'', for them to do their stuff.
  8. phantomx0_1
    phantomx0_1 Active Member
    I would still be crying.
    Feel for you. Utter tatters :-(
  9. lee711
    lee711 Active Member
    Hookin fell, how did you manage to do that ?? Gutted for you pal, that's a costly hiccup. :(
  10. Jonny fireblade
    Jonny fireblade Active Member
    Gutted bet your swear box is choca now
  11. matt
    matt Active Member
    Ouch....
  12. viper_biker
    Cheers for the comments. It's definately the worst gut turning feeling you can have when shit like this happens. Thing is, I can't explain how it happened. My original nose cone has been off and off a lot and never once had an issue. I'd put the nose cone on, fitted the wing mirrors very loosely just to hold the nose cone on and I went about putting the left panel on. All lined up and the lugs intact before even fitting a screw. I went to fit the bolt that would be below your knee when on the bike first. 2 turns of the bolt and I heard that plastic cracking noise, looked at the nose cone and this is what I found. I'm gonna be buying another new nose cone that I'm really not chuffed about, but the bike needs it along with new chain and sprockets, new tyres and I want to replace the seat fairing too. August is gonna be expensive.
  13. tonyblade
    tonyblade Active Member
    Feel for you bud, just put it down to experience and dig deep into that wallet.:)
  14. IcarusGreen
    IcarusGreen Elite Member
    It might have been faulty plastics!
  15. matt
    matt Active Member
    Sounds like they where very brittle and weak
  16. phantom
    phantom Active Member
    faulty if you ask me, they should be that brittle as
    the rr4-rr7 plastic's are thicker and more flexable
    than the newer ones.lost count the amount of times
    I had my RR5 one off and never had a problem.that
    crack is shocking for flex damage.try for a refund for faulty goods.
  17. viper_biker
    The nose cone went back to Honda, I'll find out tomorrow what's gonna happen. Hardest thing is, it was bought last year, but never fitted until Saturday. I've no idea where I'd stand on warranty, if that even applies.
  18. Andrew
    Fingers crossed you'll get some kind of result, bar accidentally stepping on it I never would have thought it would have cracked like that.
  19. phantom
    as said hopefully you get a good result from this
  20. viper_biker
    Just got word back and it's not good. If I want to replace the cowl then I've gotta buy a new one. A bit fucked off to be honest!!!
