indicator spacers
Discussion in 'General 1000RR Discussion' started by keithg1748, May 29, 2022.
  1. keithg1748
    keithg1748 Active Member
    anybody know where i can get some spacers to fir this r&g tail tidy as i am wanting to fit some led indicators , thanks .,
  2. warren smart
    warren smart Active Member
  3. keithg1748
    right i ordered some spacers and waiting for them to turn up , so i thought i would have a go at wiring them up but im stuck so any help would be great ,the new rear indicators dont work at all with the resistors fitted that came with them ? , but they work without them connected but all flashing to fast , but 4 indicators work spot on with hazards on , can anybody tell me where the indicator relay is and do i need to change it ? , thanks
  4. warren smart
    The two supplied resistors are probably to big , most decent bike shops will sell other resistors but the neatest way is definitely with a relay but I’m not sure where it is on a standard loom.
  5. keithg1748
    the 2 resistors are 18w so would you have to go higher or lower watts .
  6. PauloHRC
    PauloHRC God Like
    The holes in your tail tidy look like they're for the standard indicators ? Could be wrong?
    The standard indicators are quite nice and sleek so I used them when I fitted my tail tidy as they just plug in as before! Saves all the mither you're having now too!;)
  7. bladey
    bladey Senior Member
    When I got my present 2018 s/h it had R&G tail tidy but oe indicators. They look fine.
