Indicator wire coulour code.
Discussion in 'Mods, Upgrades, Accessories and Products' started by karlpe, Feb 21, 2016.
  1. karlpe
    karlpe Active Member
    Hi I looked at the wiring diagram for the bike, it's an 04 and I can't make sense of it, so as I want to change the
    indicators I need to identify which wire is which. On the rear there is a green wire on both sides plus another colour. Which one is the earth. Any help be good.
    Thanks
  2. teddyinc
    teddyinc New Member
    What's your other colours?
  3. ShinySideUp
    ShinySideUp Elite Member
    It would be best to check with a multimeter or test lamp but the green wire should be the battery negative/earth connection and either orange or blue wires being the live positive feed to power the bulbs depending on side.
  4. karlpe
    Thanks for the replies, wires are green and orange and green and blue both front and rear so I can assume the green is Earth as it,s at all four indicators which confirms what replies said.
    Thanks lads.
