Just fitted the AR Carbon slip on to my bike, and then found I have no way of fixing the infill panel, as I can only secure the top mounting hole, as there is no where to fasten the bottom ustilising the two fixings holes? Looked on the AR website and the panel they supply is the same as the one I have but come with two brackets. Does anyone know where these infill brackets/supports can be purchased??
Second hand can? If new should have come with the exhaust! You can contact them on the link below http://www.austinracing.info//mall/infopageviewer.cfm/AustinRacing/Contactus
Bought the can from a member on here, brand new and unused. It didn't come with an infill panel at all and as I see it, they are available separately from AR, no mention of one being included with the purchase.
Scrap the Austin infill panel it's a load of rubbish! Get a yoshimura one or a scorpion they fit nicely.
I meant if you had bought the panel new the bits should have been included! Has the previous owner not got the said parts? Being as new as you said
