Instrument panel
Discussion in 'General 1000RR Discussion' started by poppybichon, Apr 26, 2015.
  1. poppybichon
    poppybichon New Member
    Hi, Just started 2014 blade up instrument panel and head lights don't work everything else ok side lights, brake lights, indicators horn all OK it's under warranty so no problem but any idea what it could be?
  2. Cbrjay
    Cbrjay Well-Known Member
    Fuse?
  3. poppybichon
    Checked headlight fuse ok not sure where or if panel has one
  4. poppybichon
    Mr AA can't find the fault off back to Honda tomorrow
  5. RepsolPaul
    RepsolPaul Well-Known Member
    I think the headlight and dash use the same loom so I'd check the connection to the main loom and make sure it full pushed together?
  6. poppybichon
    Cheers will check that out
  7. Slick
    Slick Elite Member
    starter switch may be stuck half way down, give it a give wiggle and maybe spray with some contact cleaner
  8. poppybichon
    Cheers will have a look at that its booked in for 7th will post the findings
  9. Cbrjay
    That seems a long wait, which dealer you taking it to?
  10. Ritchierich
    Ritchierich Well-Known Member
    I had the same thing with no dash display or headlight. Looked through wiring diagram and found out the headlight is fed from the dash. I disconnected the battery, re-connected and it's all working OK again. Haven't had the problem since fingers crossed.
  11. poppybichon
    Oh kool cheers mate will try that
  12. poppybichon
    Cheers Ritchierich sorted don't you just love 2 min jobs
  13. poppybichon
    I was taking it to gedges in Eastbourne
  14. Tez57
    Tez57 New Member
  15. Tez57
    Tez57 New Member
    6 weeks out of warranty and had same thing.
    Thanks to this forum tried disconnecting the power for a few minutes. All is now well, fingers and toes crossed!!
  16. Ritchierich
    I think it may have something to do with starting the bike while still having battery charger connected causing voltage spike, that's what I reckon happened to mine.
  17. Chriscbr
    Chriscbr Active Member
    Mine has done this twice now . Around 11 months apart. Both times disconnected battery resolved problem. Always carry screwdriver now. First time it happened was at work and not connected to charger.
    Sent from my SM-N910F using Tapatalk
  18. tommy tucker
    tommy tucker New Member
    Thanks so much for that info.I had the same problem and sawv your solution so tried it and it worked a treat,but can any one explain why? I would like to know but very grateful all ok now.This forum is awsome,thanks lads.Mines a 2015 in HRC colours and i love it.
  19. Ritchierich
    Overcharging or voltage spike I reckon as mine did it when I started it with charger still switched on.
  20. tommy tucker
    thanks for that ritchierich I do use an optimate occasionally but not in this case.Last time was weeks ago and i have never tried to start with charger connected
