Iphone 6 case & mount
Discussion in 'General 1000RR Discussion' started by Sticky, Apr 18, 2015.
  1. Sticky
    Sticky New Member
    Does anyone have any recommendations for a decent iPhone 6 strong weatherproof case and a holder to fit on a '15 plate blade?
    On previous bikes (Gixxers) I had a nice secure thing which slotted into the steerer tube, but this one is capped off (although it's only a plastic cap, I haven't tried removing it yet)
  2. exuptoy
    exuptoy Elite Member
    The cap comes off ok, I have bought a Telferiser with 1 inch ball. These work with all the Ram Mount fittings too. Ram will do a case for these.
  3. exuptoy
    You can just see my ram fitting with the go-pro in the pic. It is also articulated so it can avoid picking up the clocks.
  4. RRoss
    RRoss Active Member
  5. Great Guy
    Great Guy Well-Known Member
    Huge chicken strips on that rear tyre.
  6. Sticky
    Sticky New Member
  7. RRoss
    RRoss Active Member
    Check the inside diameter of the yoke tube as you may need a new ball mount too.
    I looked at the telferizer mount that everyone mentions but that was £32 alone and by the time you add in a case and extension arm it was gonna work out much more expensive.
  8. Stevie_d
    Stevie_d Senior Member
    @Sticky
    Just bought one of these off fleebay today, should arrive by the weekend, gunna attach to left wing mirror
