Is 30psi too low ?
Discussion in 'General 1000RR Discussion' started by Broadie, Jun 21, 2024.
  1. Broadie
    Broadie Active Member
    Hi all. I find myself running down close to 30psi and it feels great. Is this too low for road use?
    I know it will reduce tyre life, but I find it a lot more enjoyable. What's your opinions.
    Cheers Broadie
  2. CharlieR85
    CharlieR85 Elite Member
    If it works for you mate then it's fine I'd say.
    Michelin say their minimum is low 20's (cold) for the Cup 2 on track.
  3. Broadie
    @bladey what do you disagree with?
    Opinions were asked for. Please share yours.
    #3 Broadie, Jun 21, 2024
  4. PauloHRC
    PauloHRC God Like
    I always run a couple of PSI lower than recommended, its just what feels comfortable for you really!
  5. bonjo
    bonjo Active Member
    is this front or rear?
    the lower the PSI, the more flex you get. It will make riding out terrible roads less uncomfortable.
    I personally don't like the road handling once dropped by more than 2 psi.
    I know different brand pressure recommendation varies from the manufacturer, pirelli used to be one
  6. bladey
    bladey Senior Member
    No idea sorry. Didn't even realise I'd touched that. I'm on a ship atm with only an old tablet which buggers about. I'll delete it.
