Jordans Bikes Leeds - £5 Dyno run Sun 17th March & Padgetts open day
Discussion in 'Events, Meetings & Ride Outs' started by Alblade, Mar 17, 2013.
  1. Alblade
    Alblade God Like
    Jordan Bikes
    Heading over for a power run - see what 'Triggers Blade' kicks out then onto Padgetts Batley for their open day
    Finally bit of sunshine here and roads drying
    Will be on black blade with white wheels
  2. fez.57
    fez.57 Well-Known Member
    I will keep an eye on this and might join you if the bike is working and the weather isnt too bad
  3. fez.57
    Hmmmm just realised thats today so i guess i wont be joining you :-(
  4. Alblade
    Alblade God Like
    Bike made 152 at rear wheel - no problems but fuelling a bit out - will scan and post up print out - ideally it needs a Power commander so the place says - one to think about I guess but power graph good shape.
  5. Si.
    Isn't that down on last Dyno run Al?
  6. fez.57
    Thats bad going i guess. let me know if there is anything else like this happening as i wouldd like to know how many bhp i have and how the bike is running.
    Dont think i could beat 152bhp on 3 cylinders lol
  7. Alblade
    Alblade God Like
    It is down - i'll scan both in. Different dyno and one could be rear wheel figure, other crank figure.
    Its done another 10,000 miles since last run
    Operator said it was about right for Blade, BMW S1k is the 180+ bike, current zx10 also high.
  8. Alblade
    Alblade God Like
    Graph here:
    The lower line in blue should match the red line - fueling would be fixed with a Power commander - will keep my eye out for one to turn up 2nd hand
    This is from 1 year ago at Padgetts of Batley
    And an early one -
    If you look at first one rear wheel power is 156, current one showing 153, ,maybe middle one is engine crank power at 173 and rear wheel would have been nearer 155?
    All 3 on different dyno machines so hard to compare side by side
  9. Alblade
    Alblade God Like
    In 5 years they have had only one problem with an engine fault - and that was already running rough and owner wanted it checked and it dropped a valve
