I have bought a us 10 to use as a tank bag but I can't seem to find an easy place to feed the straps, has anyone fitted one of these? and if so what was the best/ easiest place to route the straps! I have run out of patience already and need to do it tonight for the morning. Thanks in advance
Might be a daft question but did you get the tank adaptor as well? If so I just run the straps under the yoke, and for the back ones I put the velcro under the seat on my 07 EDIT - Just realised I have the old type connectors for attaching it to the tank adaptor.
Thanks for the reply fella! Yeah I got the connector as well, I have put the ones under the seat but can't seam to find a good route for the front due to cables! Tried around the headstock/under the yokes but only room for one side! Its on a 2012 bike if that makes any difference?
I've got kriega tank adapter on a 2012 and found best place to loop the front straps is thru the top radiator mounts,keeps them away from any moving parts and cables. I used some of that oxford rubber mat stuff to stop the straps rubbing on the tank.
