Kriega back protector options
Discussion in 'General 1000RR Discussion' started by BladeRR8, Sep 22, 2013.
  1. BladeRR8
    BladeRR8 Active Member
    Was looking at getting a back protector insert for a kriega R15 rucksack but the official kriega item is £45 for a bit of foam.
    Anyone used anything else or know if other inserts fit ok ?
  2. jamesm09
    jamesm09 Senior Member
    If its a bit of foam your after, nick one of the floats from your local swimming pool!
    Ive got a dainese back protector for under leathers if your interested. Better protection than the inserts ones for the kriega.
    #2 jamesm09, Sep 22, 2013
  3. BladeRR8
    Cheers for the reply.
    Got a dianese one myself for under leathers but tend to wear the rucksack on wet and cold days to carry waterproofs and warm clothing. As I layer up with thermals under the leathers on cold days no room for the back protector so thought might be worth fitting one on the rucksack.
  4. jamesm09
