Land line. Telephone.
Discussion in 'Non Bike Related' started by Great Guy, Dec 15, 2015.
  1. Great Guy
    Great Guy Well-Known Member
    I have a problem with my telephone. I can phone out, but when people phone the house the phones don't ring. To the caller, it sounds as if the phoneat my end is ringing. I have done the obvious checks; removed all filters and connected to the master socket, to no avail.
    To call an BT engineer costs £129! Any ideas.
  2. 1000rr73
    1000rr73 Active Member
    My brother is a telephone engineer, I'll ask him in the morning.
  3. sinewave
    How many Phone ya got Plugged in?
    Most standard BT Lines have a REN rating of 4 which is basically how many devices U can have plugged in.
    If too many are plugged in the symptoms U describe can occur.
    Unplug everything and connect just one Phone to the BT Master socket and see if that works, if it does it's an internal problem.
    If not then it could also be an external wiring problem/loose connection due to all this rain we've been having
  4. Great Guy
    Thanks
  5. Great Guy
    Thanks. Only 2 phones plugged in. The system has always worked well, until last week.
  6. sps170373
    Are they wired or cordless phones? I'd check the connection with a wired phone! Argos sell them cheap and you can take back
    If cordless I'd check batteries, any divert setting, do a master reset on them off possible and go from there
  7. 1000rr73
    Sorry, i've asked but he's being typically hard to get hold of. I'll come back when I hear.
  8. 1000rr73
  9. sp1n99
    sp1n99 Active Member
    Maybe his phones not ringing
    • Funny Funny x 2
  10. Barstewardsquad
    Isn't it only chargeable if the fault is because you have moved the master socket or if the problem is with your phone? As said get an old fashioned plug-in phone and see if that fixes it.
    If BT really do want to charge you then cancel and go elsewhere ;)
    • Old Old x 1
  11. 1000rr73
    Right, he's called me back....
    He says BT will always try and scare you off with the fixed price engineer visit if it's anything to do with your wiring. He says, insist they do a remote line check from their end.
    If it comes back ok, he says remove the faceplate of the BT master box and that should reveal a socket to plug a phone in to.... Try that, apparently it's a 2 part box, and that front part of the master contains the components to make your phones physically ring.
    Try that and see how you get on, and hopefully I've translated that right.
  12. Shutty
    Shutty Well-Known Member
    Remove the cover on the master socket and plug it directly behind it, into the line into the house, it bypasses everything into house, if it still don't work it's the line in.
    Or you just need to turn the volume up
  13. Great Guy
    Cheers done that. bt are looking in to it, apparently. Looks like line problem.
  14. ShinySideUp
    ShinySideUp Elite Member
    GGuy, do you know you keep posting questions in the for sale section of the forum??? :rolleyes:
  15. Great Guy
    This is the non-bike related section.
  16. Great Guy
    No, I don't. Give examples.
  17. ShinySideUp
    Yep the 'non bike related' in the 'for sale and wanted section'!
    It's written up in the breadcrumb area at the top of the page.
    Home>forums>for sale and wanted>non bike related
  18. ShinySideUp
    Yes you do, this telephone thread, iPad Air and your windows 10 threads!
    #18 ShinySideUp, Dec 17, 2015
  19. Great Guy
    You are correct. I never noticed these little heading before. Sorry.
  20. Great Guy
    They should be in general chat & lounge.
