Lappy bother!!
Discussion in 'Lounge' started by Haggler ®™, May 1, 2012.
  1. Haggler ®™
    Haggler ®™ Active Member
    OK guys
    Pulled a lappy out of the skip a few months ago .........Yep it worked! ..........sort of.
    It was running Windows 7,32gig hard drive of which 30gig was used to run it.........to say it was sloooooooooow is an understatement!!
    Anyhow........move things along,To-date its been treated to 2gig of RAM,Wiped clean and Windows XP loaded and to be honest runs/surfs the web ok except the friggin fan keeps running on n off alot?,I,ve cleaned the heat sink thingy and made sure the fan is "Fluff Free",and at times its slow to react ie........scrolling,paging etc.
    Any of you Techie guys know if I can shove a larger CPU in it to cure the fan from running so often and quicken things up a tad.......she's a 125cc and I,m used to 1000cc power
    E-System 3090,Intel(R) Celeron(R) M CPU,420 @ 1.60GHz,1.6 GHz 1.99GB 0f RAM
    Yes yes yes I know Noah may have used it back in the day but I like a challenge............except when it involves wasting money!
    Is there a site anyone uses?(I,ve tried crucial ).
