LED flasher Relay for 2013 Blade
Discussion in 'Mods, Upgrades, Accessories and Products' started by Scandi999, Nov 5, 2013.
  1. Scandi999
    Scandi999 New Member
    Hi - I need to change the flasher relay to a unit that will keep the flash rate unchanged when fitting LED blinkers. On the wiring diagram for the 2012 Blade (I assume it´s the same as the ´13), the flasher relay is three-pin, but when searching webshops for CBR1000RR compatible relays, they are all four-pin. Can anyone explain? :confused:Also, does anyone know if I can get to the flasher relay just by removing the windscreen, or do I need to remove the upper cowling too?
  2. Nutty Tart
    Nutty Tart Well-Known Member
    Sorry can't remember how many pins but I do remember that the front of the fairing needs to be removed ... so the mirrors as well :(
    Bit of a pain but necessary I'm afraid
  3. Scandi999
    Okay; I still got 50% of the information I asked for - thanks :)
