led indicator connections
Discussion in 'Mods, Upgrades, Accessories and Products' started by Hedges, Dec 13, 2015.
  1. Hedges
    Hedges Active Member
    Hi guys,
    Brought myself some led indicators last week for my RR5, fitted them to my panels and went to connect today and the connections are different:(
    Was wondering if I could cut the connection off my old lights then attach to these? Not sure if that can be done though? My old lights weren't led!
    Can anyone help?
    Thanks
    Hedges
  2. thezipsteruk
    thezipsteruk Elite Member
    You could do it that way, I personally cut the wire behind the original connectors and put new Bullet connectors in their place. That way I can put the originals back real easy if I ever need to for a reason.
  3. Barstewardsquad
    If you shop around you can get the proper connectors, however I ended up having to get some from Japan and it took a while. As Zippy says if you are going to cut the originals off make sure you leave enough to reattach them later, and don't forgot which colour is which.
  4. sps170373
    Motrax do link cables with oem fitment one end and bullet connectors the other, is what I used to connect my led strip back light with combined indicators
  5. sps170373
  6. Hedges
    Thanks guys, didn't realise I could get additional connectors ...... Managed to find some on eBay, should be here in a few day :)
  7. Dave
    Dave Member
    Hope you get the right ones, we had some from M&P's and took a few attempts to get the correct ones for aRR5
