LED Indicators not flashing....GRRRRRRRR!
Discussion in 'Maintenance' started by RedBull, Dec 19, 2014.
  1. RedBull
    RedBull Member
    :mad::mad:
    Both my LED indicators were working fine, but one required changing as it was cracked. I also have a rear cluster with indicators built in, but i don't use this currently as its an MOT fail.
    All I have done is made a positive Y-split from each left and right indicators looms. In order to incorporate both the indicators and the built indicators within the rear cluster.
    I had it working with the old indicators, then all of a sudden it stopped :(
    All i have is a solid amber light, no flashing.
    I checked the fuses. 2 of the 10A fuses were blown, I've replaced them.....Still a solid amber.
    The bike starts and works fine.
    Does anyone have any ideas on what the F@$# is wrong?
    Regards
    RedBull
  2. sps170373
    Might be the indicator relay
  3. ShinySideUp
    ShinySideUp Elite Member
    Relay would be my guess too.
    Does the relay click when the indicators are turned on?
    I take it the lights are only solid amber when each side is turned on and not all the time?
  4. Pitcrew1
    Pitcrew1 New Member
    The majority of indicator relays rely on a load (wattage = amps) to make the flash rate, ie, front and rear lamps = 2 x 21watts. If you use LED indicators without a load resistor added, then the relay will not function. Also if you happen to connect the LEDS the wrong polarity, you create a short circuit (fuse blows). So, either buy a solid state relay which will operate LEDs or add resistors to get a normal relay to operate (wattage rating is critical or it gets too hot).
    #4 Pitcrew1, Dec 20, 2014
  5. RedBull
    RedBull Member
    The relay doesn't click when the indicators are turned on. And yes they are only solid when they are switched on.
  6. RedBull
    RedBull Member
    My previous indicators were LED and worked fine. The problem occurred prior to fitting the new LED indicators. I had both my old indicators flashing and the built-in indicators within the rear cluster. I was figuring out which wires were going to go where.
    Then all of a sudden it stopped. I checked the fuses on the front left fairing - 2 of the 10A had blown. I've replaced them. But I'm still getting no flash :(
  7. Pitcrew1
    Pitcrew1 New Member
    Yep, as said, sounds like the relay has damaged, if you know someone with another blade then swop it out before buying a new one.
  8. RedBull
    RedBull Member
    I would swap it out, but I have no idea where it is?
    The relay is playing hide and seek :(
  9. sps170373
    Usually attached to the headlamp behind the cowl unfortunately
  10. Gilesy
    Gilesy Elite Member
    Its usually behind the left side fairing, beside the fusebox..
  11. sps170373
    Ah yes sorry mines a later model
  12. Barstewardsquad
    RR4-5 - Behind front cowl
    RR6-7 - Left hand fairing
    Don't know about newer ones.
