Left hand grip loose
Discussion in 'General 1000RR Discussion' started by rollsroyce, Nov 1, 2013.
  1. rollsroyce
    rollsroyce Member
    Hi, any idea as to the best way to fix my left hand grip, i have tried epoxy resin, but it soon came loose again, its dam annoying now.
  2. Jkaye
    Jkaye Active Member
    Remove the grip, degrease both the bar and inside the grip add a smear of clear silicone sealant and replace grip , sorted once the silicone has had time to cure.
  3. scooby
    scooby Elite Member
    if it's loose sounds like it's worn.
    either put a new grip on or just lockwire it on.
  4. rollsroyce
    rollsroyce Member
    its a newish one
  5. rollsroyce
    rollsroyce Member
    Doh, forgot to say thanks for the tip, will do it this weekend as weather is going to be shit
  6. Nutty Tart
    Nutty Tart Well-Known Member
    I used hair spray once to fit 'em .... worked too :D
    These days I use Renthal grip glue
  7. jamesm09
    jamesm09 Senior Member
    All I do is clean the handlebar then spray the inside of grip with brake cleaner. Never bother with the glue and they have never moved on me yet.
