Levers
Discussion in 'General 1000RR Discussion' started by jmatt, Aug 3, 2013.
  1. jmatt
    jmatt New Member
    Hi i looking to put aftermarket clutch/brake levers on my 2011 blade,but which ones? TITAX, PAZZO or ASV, whats the difference apart from price, Help!!!!:confused:
  2. levin
    levin Active Member
    I just prefer the look of asv's , I got a used set off the forum so price wasnt an issue:)
  3. martinowen
    I love the Harris ones
  4. ColinBR
    Between the 3 that you have listed there I would say ASV's asthey have more adjustment.
    But as above the Harris 1's are also really nice.
  5. raphael
    raphael Elite Member
    I would go with the harris all day look/feel lovely and cheeper
  6. iang27
    iang27 Active Member
    I used to sell the 'Harris' ones, they are made by TWM, only problem with their cable clutch lever was it did not have an adjuster on it.
  7. jmatt
    jmatt New Member
    I've just had a look at the Harris levers and yes they look good, thanks for that martin!! Now I've got 4 levers to think about lol.
  8. martinowen
    Lol oops
  9. RRoss
    RRoss Active Member
    Got the ASV shorties on my new blade and they look and feel great:)
  10. ShinySideUp
    ShinySideUp Elite Member
    I have the Pazzo levers fitted to my bike and they work and feel pretty good, the Titax levers looks pretty similar but have not used em before. The Asv levers are nice too and to me a more finished product with rounded edges rather than the more machine finished chamfered edges found on the Pazzo units.
    To me levers are pretty subjective thing and it's more about looks than anything else otherwise why change from the stock levers that do the same thing as any other, ok aftermarket units can give more adjustability but isn't that why the cables have adjusters put in them!
    The Pazzo units fitted to my bike have quick adjusters for both clutch and brake, the quick adjusters lime stock brake lever allows the lever to come closer to the bar for small handed folks but the final adjustment is done via the cable. I found the clutch quick adjuster can't (or shouldnt) be altered on the fly as using the quick adjusters after the cable adjuster is set can lead to either the clutch slipping or not disengaging depending on which way u go with the adjuster.
    Sorry for long post which may or may not help with your choice.:)
  11. sinewave
    Pazzo's on mine, just as good as ASV's but cheaper and more exclusive!
    Every Dog and his Dick has ASV's!
    having said that those Chinese Cheapy's off Fleabay have had rave reviews from members on ere that have 'risked it' for £30
  12. rewy..rr
    rewy..rr Active Member
    Had Titax on my r1...
    Lots of adjustment, and well made...
  13. HRC Wyn
    HRC Wyn New Member
    I had some Chinese levers on my GSXR for over 3 years, never had an issue with them. I'll be ordering some for the blade soon.
  14. jmatt
    jmatt New Member
    Thanks for all the advice guys.
  15. mr.h
    mr.h Active Member
    I had ASV shorties on my 2010 & 2012 blade, went for Pazzo on my Speed triple... just ordered a set of ASV's for the Speed, much more adjustment and look...better. you pays your money you takes your choice!
    One more thing - normal or short length ????????? 2 more things to consider! :eek:
  16. martinowen
    There is an eBay seller that sells pazzo's for 110 new if that helps
  17. mr.h
    mr.h Active Member
    yeah but ASV's are only a little bit more expensive but the quality shows - style over substance... just sayin' :)
  18. jmatt
    jmatt New Member
    OK, now advice on short or standard levers, what's the drawbacks or plus's on shorty levers ?
  19. ShinySideUp
    I've got best of both, standard size clutch and short brake lever!
    The short clutch lever can cause a lot of fatigue when in a lot of stop start traffic.
  20. ColinBR
    Exactly the reason why I changed to long levers.
    If I had the choice I would do the same as above and have a short brake lever and a long clutch lever.
