Light bulb
Discussion in 'Maintenance' started by Great Guy, Aug 15, 2017.
  1. Great Guy
    Great Guy Well-Known Member
    I have just noticed that my front light has gone( the one which is permanently on)
    Where do I get one from and how much? Is it easy to replace? Thanks.
  2. sps170373
    It's just a standard h7 bulb so anywhere that sells bulbs! I've swooped mine over to led's which I purchased off of eBay much better and brighter
  3. sulaco
    sulaco Active Member
    I use night breaker plus, good light reasonable value, When I have my low beam go I usually pop the high beam bulb over to the low beam and put the new bulb in the high beam side. My high beam hardly gets used and I probably go through 3 lows to one High.
  4. Great Guy
    Is it 55w? I believe the 100w melts the housing.
    Can one swop them over or is the other one set differently?
  5. sps170373
    I've used 100w before with no problems
  6. Great Guy
    H7 halogen 55w dipped beam. £4.99. Is this the one? eBay.
  7. sulaco
    The bulbs are the same in each side, It's the housing that changes the beam.
  8. sulaco
  9. Great Guy
  10. sulaco
    Not the same year but the same procedure:
  11. TheRamJam
    TheRamJam Well-Known Member
    Yup H7s both sides whether high or low beam
  12. Great Guy
    What does all that mean. Do I need high or low beam? What is the difference? Thanks
  13. sps170373
    Perhaps you ought to get your wife to change them if you don't know what he means :D
    • Funny Funny x 5
  14. Great Guy
    Lol. Already taken old one out, new one on its way.
  15. Great Guy
  16. Great Guy
    They are everything. Low, high, middle, modal and median beam.
  17. rebel
    rebel Active Member
    hi have you got a link for the leds thanks
  18. sps170373
  19. BlackDevil
    BlackDevil God Like
  20. hitch
    hitch Elite Member
    If you compare the night racer to night breaker they are identical.
    The night racer description is simply a copy and paste of the night breaker - with some changes to make it read for bikes but near the bottom the perosn repsonsible must have lost interest because it goes back to the car references as per the car version.
    Not sure what my point is, but I hope I made it clearly! :eek::oops:o_O
