Lightech chain adjusters
Discussion in 'Mods, Upgrades, Accessories and Products' started by Froggypimp, Sep 27, 2013.
  1. Froggypimp
    Froggypimp New Member
    I´ve just replaced the original chain adjusters with a nice set of Lightech adjusters. Nice bit of kit...:)
    Do I have to reuse the original washer when putting on the rear axle nut or can I just use the rear axle nut without the washer?
    The washer almost cover the indicator markings on the Lightech adjuster and makes a nasty grove in the adjuster.
  2. MrB
    MrB God Like
    I used the washer when I had them fitted.
  3. Skippy79
    Skippy79 Active Member
    use the washer or buy the axle nut from lightec, its got kind of a washer built in, you'll get me when you see it ;) then you won't need the oem washer..
    btw they are lovely pieces of kit
