Hi All I’ve picked up some second hand lightech rearsets but there’s no instructions with them. They seem pretty straight forward but I’m not sure if all the parts are there so if anyone has them and has fitted them can I check the following: fitting to a 2011 bike. Does the left hand side need any spacers or does it just bolt directly to the frame On the right hand side do you need to space it out to accommodate an akra can (my Gilles ones has some aluminium spacers where they mount to the frame? Does the exhaust mount use the standard bush and fittings as it’s different to the Gilles one. Thanks in advance Mike
From memory they didn’t require any spacers, the only thing I needed was a pressure switch for the brake light.
