hi just changed oil 2013 , but struggling to put standard belly pan back on ,its doing my head in any tips , thanks.
I fix on with the rear 2 bolts first (loosely in), lift the front into position, clicking the tabs that locate with the side fairing into place (1 side at a time), then put the front bolts in and tighten all 4 bolts up - works for me.
top tip , next time don't remove the fairing , Honda mechs don't, they have a plastic half pipe that fits under the filter to direct the oil past the fairing and the drain plug misses the fairing anyway. note:- this is only on 12's onwards
