LSL Tour Match Kit anyone fitted them??
Discussion in 'Mods, Upgrades, Accessories and Products' started by mpgscott, Oct 5, 2012.
  1. mpgscott
    mpgscott New Member
    Hi Folks,
    Looking to see if anyone has fitted one of these kits before http://www.spieglerusa.com/tour-match-kit-4648.htm ?? I have bought one for the RR5 and just wanted to see if anyone had any fitting pointers?? My bike has goodridge hoses on her and this kit seemingly raises the bar 70mm and back 40mm so will i need to extend the lines??
    Any thoughts much appreciated.
    Cheers
    Mark
  2. ColinBR
    I think you do have to get longer lines. Not sure about throttle cables but the brake and clutch lines I'm sure you do. You may get away with it with the aftermarket 1's you have as they are slightly longer.
    If you need longer lines give arthurbikemad a shout as he can get custom HEL lines made up for you.
  3. mpgscott
    mpgscott New Member
    Cheers for the heads up, i will give them a try and see how i get on. Looking at it i could maybe rotate the throttle and have the cables out the bottom. Cant seem to find anything on the web to say if its required, think the clutch line is standard length on my bike.
  4. ColinBR
    I would try them out first as you said. Don't know how it would go with turning the throttle tube round though as you may have problems when at full lock. But defo worth trying things first.
  5. Hudson
    Hudson Active Member
    Been thinking about these for my 954 as i can not seem to find the Heli-bars, my concern is linked to the fairing and ensuring i don't need to cut it or alter it at all.
