manual cam chain tensioner
Discussion in 'Maintenance' started by uncle numpty, Jul 4, 2013.
  1. uncle numpty
    uncle numpty Member
    has anybody had any experience of fitting one of these to a 08 blade,do you have to remove cam chain cover and cam chain guide or just put it to tdc and remove old and replace new.
  2. dogman
    dogman Member
    Not on a blade, but VTR1000, just set at TDC and replace.
    The main issue is usually access both for installing and setting the tension.
  3. Jimbo Vills
    We done Dave v's was a piece of piss....
    Access a little fiddly, but take old one of, bolt new and pull the pin, sets the tension automatically. Just remember to put the final nut on before starting the bike ;) jimbo / Dave near miss lol
    Well that's my simple interpretation of it - I was drinking tea and not paying a great deal of attention at the time!
    Dave will firm up details though I'm sure
  4. Dave V
    Dave V Elite Member
    Lol, all that tea went to our heads!
    Like Jimbo says, nothing to it really other than being patient. Sure the service manual says take the air box off, we didn't bother.
    Take the right hand fairing off.
    Take the tank off, may well be able complete the work without having to but thought this would be so much easier.
    Undo the middle tension bolt
    Undo the two retaining bolts
    Pull the old unit out
    Replace the gasket
    Offer the new one up
    Replace the two retaining bolts
    Pull the pin thing that comes with the OEM replacement tensioner- this is where it's going to be different if you fit a manual unit.
    Squirt a little oil down the hole
    Replace the centre tension bolt.
    Replace the tank, run the bike to check any leaks etc
    Replace the fairings
    Rag the bike
    To be fair this is replacement for a like for like unit, eg not manual.
    I did look into replacing the OEM with a manual unit. Actually fitting the manual version can't be any different to the OEM.
    The actual adjustment on it also looks a doddle, it's just the centre bolt. I read that you can complete the adjustment by feel, but this is where I decided to not go the manual root as just couldn't get my head around how you can get the tension right without checking the actual cam chain itself, which would be a ball ache if it had be done say every 5k or something. But then I'm new to working olmy own bikes and others on here have far more experience and may be able to provide more information on how to adjust the manual CCT.
    #4 Dave V, Jul 5, 2013
  5. gav77
    gav77 New Member
    Did mine with no problems, TDC, remove tank only took about 30 mins mate ;)
  6. uncle numpty
    uncle numpty Member
    where are the marks for tdc,how do you know it was at the right tension.
  7. Dave V
    Dave V Elite Member
    If its worth anything, didn't even consider tdc bit again this is based upon a like4like replacement.
    Is everyone getting the detail of the original question which is around fitting a MANUAL cct?
  8. gav77
    gav77 New Member
    Remove the timing cap from the clutch cover 17mm socket then you'll see the marks inside, turn the crank clockwise 14mm socket and align the marks up mate
    #8 gav77, Jul 6, 2013
  9. armymanmike91
    armymanmike91 Active Member
    Just wondering where did u get your manual tensioner from, i need one lol
  10. uncle numpty
    uncle numpty Member
    just type ape camchain tensioner in google,and you will find someone on there to get it from,i cant remember the name of the company i dealt with.
  11. gav77
    gav77 New Member
    I got mine off eBay mate £63
