Master Cylinder Upgrade
Discussion in 'Mods, Upgrades, Accessories and Products' started by BoroRich, Apr 27, 2020.
  1. BoroRich
    BoroRich Elite Member
    Morning everyone.
    With boredom thoroughly set in I'm considering an upgrade to the bike in the form of a Brembo RCS and braided lines.
    Question is, is it worth it? Anyone got any prior experience?
  2. nozdog
    nozdog Active Member
    I fitted a Brembo RCS and Braided line to my track bike which made the world of difference was night and day performance much more fell and better braking, if just for the road I'd just fit some HEL brake lines and SBS RS pads which also is a good upgrade.
  3. Slick
    Slick Elite Member
    If you don't like the soft feel and long travel of OEM then RCS or similar is worth wide.
    Ran an RCS at the ratio that provides shorter travel (IIRC 20mm) , but both ratios the lever was much harder than the soft OEM.
    My current Blade is running standard ( I don't do track day anymore) considering refitting the RCS but in no hurry , I guess your body just adapts to working with inferior parts bit like the feeling when you put on new tyres. but I bet when I put it back on I will think why I didn't do it earlier!
  4. Slick
    Slick Elite Member
    Just to note it's got a weird ass size bleed nipple, depending on your line config the banjo is the wrong length, factor in cost of reservoir mods ( I used a lady bird and OEM bottle) and you'll probably want a matching clutch lever
  5. raphael
    raphael Elite Member
    once you’ve gone to a brembo ar acassato master it’s will be the first thing you do on your next bike as it’s night and day difference imho mate
    • Disagree Disagree x 1
  6. BoroRich
    I noticed that the Accossato ones were a little cheaper. It's just for road use so one to consider?
  7. Slick
    Slick Elite Member
    Not sure about the Accossato as they may have it as well but the RCS19 has both 20 and 18 ratios and brake light switch.
    I think they say 20 for the road- response, 18 for track - power and modulation.
  8. Slick
    Slick Elite Member
    Mines been in the shed for a year and half and you've just convinced me to refit it! Not as if I have no time to fit it lol
    • Funny Funny x 3
  9. tuktuk
    tuktuk Elite Member
    I've said this before but I wouldnt recommend the extra for the corsa corta. I stupidly paid extra and swapped an RCS 19 for the above and there was no need. The normal one is a big enough upgrade and for the cost they are a brilliant.
  10. raphael
    pretty much identical to the brembo mate, speak to mike on here @BikersDiscountStore knows his stuff and very helpful.
    • Friendly Friendly x 1
  11. raphael
    mimes the 20 ratio Jon, les lever travel and instant power and lots of feel.
    Would be the first thing I changed on a bike now mate.
  12. Slick
    Slick Elite Member
    Once my brake pistons are polished and calipers back on the RCS is next
  13. stuart_g
    stuart_g Active Member
    I would love to do this to my bike. They go to the lengths of fitting Brembo calipers as standard and then the crappy standard master cylinder lets it all down.
    I suppose it is personal taste on how you want the brake lever to feel but me personally i like less lever travel, harder feel and more bite.
    My last blade (2012) i put Hel lines on the front, didn’t bother with the rear as i hardly use it and found it powerful enough. Went for two lines from master cylinder, one to each side. I didn’t really think it made that much difference over standard.
    This time around i would fit the master cylinder and see how it felt with standard hoses especially with the abs on the SP2 and bleeding the lines etc.
    Let us all know what you go for and what the end result Is.
  14. Slick
    Slick Elite Member
    I've used the RCS on both abs and non abs. the Abs trickery negates much of the advantages but you do still get much shorter travel. This is on an 09 abs, not sure if the sp2 abs works the same way though
  15. BikersDiscountStore
    If anyone's interested in a master cylinder upgrade and is looking at Accossato while this lockdown is on we'll throw in 2 x Hel brake lines foc.
    • Like Like x 6
  16. BoroRich
    Haha!! I was just about to contact you :D
  17. BoroRich
  18. GappySmeg
    GappySmeg Well-Known Member
  19. raphael
  20. stuart_g
    What about the front brake switch on the accosato? Looked on BDS website and it looks like you have to use a hydraulic one. My experience with this type is that they need a lot of pressure to work and can be a bit hit and miss. Is there a normal mechanical switch option? Also struggled to find a clutch lever to match either the folding and one piece lever.
