Hi. Sorry if this has be covered. But couldn't find the info I needed. The problem The front brake is crap. Doesn't fill me with confidence at all. I can pull the lever back to the bar. The plan Front brembo M/C from a bike that has one fitted as standard. IE, R1 s1000rr The questions On a 2019 SP bike with the abs and electrical gubbins. Am I going to run into faults? Anyone done this before? Can I foresee any other problems? I know the RC kits are out there. But they're £250+. The OEM brembo M/C are better than ours so a cheaper viable option. I think even the nissin fitted to my r6 was better. Also I'm planning on changing my levers. This will make it easier to match them. Again apologies. And thanks in advance.
