Messed up my sticker
Discussion in 'Mods, Upgrades, Accessories and Products' started by RepsolSam, Jul 20, 2016.
  1. RepsolSam
    RepsolSam Well-Known Member
  2. Muffking
    Oh feck, the bubbles will be easy, but the line you can only make smaller.
    For the bubbles apply heat from a hair dryer and put a pin prick in the centre to expel the air as you press down with your finger.
    For the line, unless you can lift the bottom then apply heat while running your finger down the line to try and smooth it out. You'll probably need to pin prick this too.
  3. RepsolSam
    Bummer, no time now. ...at race by design in the morning getting ventura shield put on...I wonder if they will sort this for me..
    If not I have the other number I guess..
    Sent from my SM-G925F using Tapatalk
  4. 1000rr73
    1000rr73 Active Member
    I reckon they'll sort it for you. When I was there I saw all sorts of wizardry and trickery with vinyl. Don't forget to remind them they have the seat cowl template off of my bike (it isn't part of the standard kit)
  5. TheRamJam
    TheRamJam Well-Known Member
    get a hair dryer and peel it back off and try again
  6. RepsolSam
    @ race by design...they said they can't fix...but can replicate and make another one..
    Told them just to take off and put the other number on...
    • Optimistic Optimistic x 1
