Micro switch/pressure switch question
Discussion in 'Mods, Upgrades, Accessories and Products' started by jace1rr, Mar 3, 2023.
  1. jace1rr
    jace1rr New Member
    Hey folks,
    Just installed Spiegler steel braded lines (Rennsport 1 to 2), Brembo monoblocks, and Brembo 19x18 master, but want to make sure I order the right micro switch or pressure switch for my 2009 CBR1000RR so my rear tail still activates. Bike is 50/50 track street.
    From the looks of it, both need splicing into the OEM switch wiring by the master cylinder.
    Any links just to ensure I grab the right part would be a huge help!
    Jace
  2. vic_ster51
    vic_ster51 Active Member
    Brembo do they own microswitch for the rcs19 you can buy they universal as such wiring wise but yeah better than pressure switch. Saves you bleeding again aswell
    You will need to splice into oem wiring or just match connectors to oem to install on the brembo side
  3. Slick
    Slick Elite Member
  4. jace1rr
    jace1rr New Member
    Exactly what I'm looking for but I'm not sure if this mounts to the 19x18 as it seems to have just one screw hole underneath. Any suggestions?
  5. Slick
    Slick Elite Member
    Oh ok, this is specifically for the RCS series, would suggest a pressure switch is a easier option
