Mixed Nuts, Bolts & Washers
Discussion in 'General 1000RR Discussion' started by RepsolSam, Apr 28, 2014.
  1. RepsolSam
    RepsolSam Well-Known Member
  2. Dave
    Dave Member
    Hi Repsol, both packs are reasonable, the plating on the zinc plate nuts & bolts is not specially clever but for the price hey. Also something to remember is that once you go past M8 the pitch of the thread is not the same as Honda pitch therefore you cannot wind a M10 screwfix bolt into the Honda Threads. Also note it is strongly recommended that you use copper slip or quick silver on stainless fasteners as they have a bad habit of "picking up" ie jamming and you'll never get them apart if they do. Dave
  3. northseawarrior
    northseawarrior New Member
    careful where you use stainless bolts has it doesn't have the tensile strength of steel
  4. PeterT
    PeterT Active Member
    Stainless comes in either A2 or A4 , the later being better quality mainly used on boats outside fittings etc. Stainless not to be used on any stress related parts including caliper bolts/suspension.
  5. PeterT
    Metric threads used on the Honda vary from standard pitch, including 1.25 and .15 fine. So be careful when you screw bolts in. Check with a thread gauge first if you have one!!
  6. RepsolSam
    well i bought the smaller one...found they are not very long..but will sit int he garage as may come in use one day...
